Date/Time: Mon, 23 Dec 2024 01:08:16 +0000
Trade with target and stop loss
View Count: 847
[2015-09-05 06:17:21] |
User569811 - Posts: 3 |
Dear All Whenever I am placing a trade with 1 stop loss and 1 target on the SIMULATION account i am getting the following error. "TRADE ORDER ERROR:PARENT PRICE IS MORE THAN 25% DIFFERENT THAN ORIGINAL ATTACHED ORDER PRICE". Kindly advise Date Time Of Last Edit: 2015-09-05 06:47:49
[2015-09-05 06:47:09] |
On the Targets tab of the Trade Window for the chart, this indicates that the Limit Offset and Stop Offset are not set correctly. What are they set to? And did you select Ticks or Price for the offsets? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-05 06:47:31
[2015-09-08 19:02:38] |
Dear All Thanks for the prompt reply. I am fine with that error I was not paying attention in choosing between tick option and price option. Regards Charbel Gebara |
