Date/Time: Mon, 23 Dec 2024 00:32:07 +0000
Replay Chart in version 1292 not working
View Count: 882
[2015-09-05 06:12:26] |
fireworks11 - Posts: 63 |
Please check on the Replay Chart feature in version 1292. I can't get it to work. Many Thanks.
[2015-09-05 07:14:32] |
We tested it now and it does work properly. Nothing changed which would have caused this problem. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_ReplayChart.html#BasicInstructions Let us know at what point you experience a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-05 07:15:13
[2015-09-05 07:35:44] |
I found the problem: the replay window was not visible. I followed the instructions to make it visible and everything is fine now. Sorry to have caused any trouble. Many thanks again!!!
Date Time Of Last Edit: 2015-09-05 07:38:36
