Date/Time: Sat, 19 Sep 2026 23:00:41 +0000
Count number or trades per day
View Count: 1415
| [2015-09-04 17:38:24] |
| pkhst958 - Posts: 57 |
Hi all, how can I count the number of trades per day? THX |
| [2015-09-04 18:58:40] |
You need to set the chart bars to 1 day per bar. Refer to the documentation here for this: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TimePeriodPerBar And use the Number of Trades study. This can be added through Analysis >> Studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-09-04 19:21:42] |
Thanks for quick reply :)
