Date/Time: Mon, 23 Dec 2024 01:04:51 +0000
indicator dont work
View Count: 1165
[2015-09-04 15:13:24] |
User687985 - Posts: 12 |
hi, i downald an indicator and i want to use it with sc platform.when i open the indicator i get amessage saying that this indicator caused a CPU exception and sc platforn can be unstable when we use it. I used this indicator with SC platform befor and never had this problem till today. Can u please help to resolve this problem.I attached the indicator below Regards |
DailyRange.dll - Attached On 2015-09-04 15:13:18 UTC - Size: 10.5 KB - 348 views |
[2015-09-04 18:02:52] |
There can be different causes of this problem. The very first step is to get the source code for it and recompile it. Did you download this file from this Support Board? This is the relevant help topic about this: http://www.sierrachart.com/index.php?page=doc/helpdetails17.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-04 18:10:17] |
yes i downald it from here https://www.sierrachart.com/supportboard/showthread.php?t=25348
[2015-09-04 19:07:10] |
Assuming that you want "Daily Targets", this will be added to the User Contributed Studies in the next release of Sierra Chart. We have taken the source code and included it. You will find it in Analysis >> Studies >> Add Custom Study >> User Contributed Studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-04 20:06:55] |
When the next release of sc platform will be? I was using this inficator without any problem till i downald the last version of sc platform than it stop to work. |
[2015-09-04 20:47:04] |
We will have a new release out next week.
[2015-09-06 10:41:52] |
hi, Can u please tell me what is the exacvte date when the next release of SC will be? What i must do to get the last release of SC? Regards |
[2015-09-06 22:04:45] |
We do not know the exact date. However, it will be the prerelease updated first. We do not expect it would be later than Wednesday or Thursday. Follow the instructions here to update Sierra Chart: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
