Date/Time: Mon, 23 Dec 2024 00:20:46 +0000
horizontal line and ray to show price
View Count: 2596
[2015-09-04 12:20:50] |
User12089 - Posts: 361 |
How can you make the horizontal line or ray show the price - whether somewhere above the line or in the price stripe on the right
[2015-09-04 17:35:01] |
Sierra Chart - Max - Posts: 5756 |
Open the Chart Drawing Properties for the Horizontal Line or Ray: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartDrawingProperties Go to the Labels tab, and enabled Price. Press OK. Sierra Chart Support Date Time Of Last Edit: 2015-09-04 18:50:01
[2015-09-04 19:44:19] |
thanks but how do you make that a default setting so to avoid doing it every time
[2015-09-04 21:02:13] |
You need to change this in the Tool Configuration window for the Drawing tool: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DrawingToolConfiguration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
