Date/Time: Sun, 22 Dec 2024 22:57:41 +0000
Charts
View Count: 804
[2015-09-03 22:42:34] |
User460383 - Posts: 2 |
My Charts stopped updating at 6;30 eastern time. Is there a problem on your end? Thank You; David Zanni |
[2015-09-03 23:52:31] |
No and in any case that would not affect the particular data feed and trading service you are using. Refer to help topic 3: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
