Date/Time: Sat, 12 Sep 2026 14:55:16 +0000
CME Group
View Count: 1221
| [2015-09-03 19:44:19] |
| User713273 - Posts: 409 |
Switching from IB to SC for data, what is the symbol for IWM under cme group. Im having some difficulty finding it. Thx
| [2015-09-03 19:47:15] |
or just having issues connecting to the feed
| [2015-09-03 19:49:19] |
What is IWM? Provide us a link on the CME website for this particular contract. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-09-03 19:50:22] |
iShares Russell 2000® (ticker: IWM)
| [2015-09-03 19:55:17] |
Therefore, this is a New York Stock Exchange symbol. Not a CME Group symbol. You need to activate the US Equities or the BATS exchange. Not CME Group. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-09-03 20:05:44] |
Ok thx, can you refund cme group
| [2015-09-03 20:06:26] |
| [2015-09-03 20:08:06] |
Yes we can. We will do this.
