Date/Time: Sun, 22 Dec 2024 22:39:30 +0000
What in heavens name have I done?
View Count: 894
[2015-09-03 17:54:38] |
User11638 - Posts: 21 |
I was looking at the menu options on the DOM and believe that I clicked on Trade>>Chart Trade Settings. Now I cannot select anything from the DOM menu, nor can I select anything from the primary chart in the chartbook, including the tabs to close Sierra! I just get the 'not allowed' beeping noise. What in heavens name have I done? |
[2015-09-03 18:26:48] |
Don't ask me, but the system is working normally now.
[2015-09-03 18:37:43] |
SgtJ - Posts: 154 |
You likely opened a menu that was out of view. When this happens press the esc key.
[2015-09-03 18:46:39] |
Yes, when this happens press the Escape key. What happened is that there was a problem displaying a dialog window. Sometimes this can happen on a Windows system for unknown reasons and generally the solution is to close some programs or restart the computer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
