Date/Time: Mon, 23 Dec 2024 01:41:12 +0000
[User Discussion] - GER30 missing Data
View Count: 1407
[2015-09-03 17:07:08]
tomtom - Posts: 53
In GER30 Historical Chart,1 Day
starting jun 2000 till march 2009 all mondays are missing, so the week is only 4 days
greetings!
[2015-09-03 17:33:15]
This was the data we obtained from FXCM. There is nothing we can do about it.
[2015-09-03 17:39:10]
tomtom - Posts: 53
i know, i complaining this last jear in october. its because any update caused this, and all my historical and backstest lines are wrong. that is very annoying :(
[2015-09-03 19:48:41]
Open a Historical Daily Chart for this symbol:
DYY00
This will give you the proper data for the DAX.
Date Time Of Last Edit: 2015-09-03 19:49:28
[2015-09-04 07:58:27]
tomtom - Posts: 53
Thanks, that helps days are complete , but the horizontal lines remain false, exactly 1 day beside
[2015-09-04 08:06:00]
We do not understand this, please be more clear.
[2015-09-04 14:15:54]
tomtom - Posts: 53
Before it was like the blue lines in the middle of the candle, now is like the yellow lines... beside
Date Time Of Last Edit: 2015-09-04 14:16:42
imagechart.jpg / V - Attached On 2015-09-04 14:14:59 UTC - Size: 127.76 KB - 343 views
[2015-09-04 14:22:53]
tomtom - Posts: 53
i seem to remember it happened when i made any update from old spreadsheet to the new
[2015-09-04 17:50:58]
What about those yellow and blue lines through the candlesticks? What is drawing them? We really are not understanding this at all.
[2015-09-05 13:08:54]
tomtom - Posts: 53
These are only personally system marks for manual backtest, at first they were centered in the candles after any update beside the candles. The Chart is an example, blue line positions was before, yellow line positions is now
Date Time Of Last Edit: 2015-09-05 13:11:26
[2015-09-06 23:09:49]
There will be some pricing differences between DYY00 and GER30
[2015-09-07 07:22:11]
tomtom - Posts: 53
i want only a solution for the fault lines in GER30 which has moved beside after any update
because I thought it is up to the missing days
DYY00 was recommended from you for the missing days I noticed after manual review in GER30
DYY00 is Data from Dax Index, GER30 is Data from Dax future data. i prefer GER30
[2015-09-07 07:26:08]
The data is what it is for each of the symbols.
There simply is not any further help at all that we can provide with this.
[2015-09-08 13:38:46]
tomtom - Posts: 53
then I hope that my lines yet fit after each update
[2015-09-08 17:20:49]
After each update of what? If you are referring to Sierra Chart, the data will never change with Sierra Chart versions. It cannot.
