Date/Time: Sun, 22 Dec 2024 22:51:32 +0000
[User Discussion] - Macros/Key shortcuts
View Count: 1350
[2015-09-03 16:54:11] |
User832215 - Posts: 27 |
Hi, Why haven't you made it possible to assign shortcuts to mouse buttons? The mouse is pretty much the one thing that I'm using the most and with the ability to assign mouse buttons with any tools would be very convinient |
[2015-09-03 23:50:11] |
Hieronymus - Posts: 51 |
I have an 18 button mouse and they are all assigned a Sierra Chart tool or action. It's not the trading softwares job to do this, it's your mouse and its softwares job.
Date Time Of Last Edit: 2015-09-03 23:50:38
[2015-09-04 05:42:46] |
Kiwi - Posts: 375 |
If you're running windows get some software called autohotkey. If you're running Linux then get the slightly better autokey. Both are free and enable learned and/or programmed hotkey development. I have found that the Sierra team will readily provide new command/key links if there is anything that Autokey can't get a handle on. But its really up to the user to provide their own customization - why reinvent the wheel. |
