Date/Time: Sun, 22 Dec 2024 22:29:23 +0000
Ticks per volume bar in Volume by Price
View Count: 1236
[2015-09-03 12:26:14] |
Guilherme - Posts: 66 |
For some unknown reason, I cannot reduce the value for "ticks per volume bar" in my Volume by Price indicators. It's set in 5, and when I try to put it in 1 and apply it, it comes back to 5 again.
[2015-09-03 18:07:58] |
Go to Chart >> Chart Settings and set the Volume at Price multiplier to 1. After this you can change the Ticks per Volume Bar input for the Volume by Price study to 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
