Date/Time: Sun, 22 Dec 2024 22:56:11 +0000
Login screen freezed
View Count: 1635
[2015-09-03 11:37:51]
Guilherme - Posts: 66
Hi. I just installed Sierra in a new machine, a Windows 2012 server at Amazon AWS. The first time I tried to log in, I used a wrong password. After reporting an error message, I try to enter the correct password but it freezes. If I kill the process and execute it again, the same thing happens, over and over.
Date Time Of Last Edit: 2015-09-03 11:39:23
image2015-09-03_08-38-18.png / V - Attached On 2015-09-03 11:39:04 UTC - Size: 81.61 KB - 321 views
[2015-09-03 11:49:55]
We will have this fixed, but it is going to take us about 6 hours.
For now go back to version 1288 or earlier which you can download from this section here:
https://www.sierrachart.com/index.php?page=doc/download.php#Rollback
Date Time Of Last Edit: 2015-09-03 11:52:51
[2015-09-03 11:53:51]
Actually another temporary solution is going to be to press the Cancel button as soon as you see the Login window appear and then correct the Account Name and Password.
[2015-09-03 11:56:46]
This is regarded as a serious issue, and the main release of Sierra Chart has been reverted back to version 1282.
[2015-09-03 12:27:02]
infpz - Posts: 826
I am logged into 1290 and it's working fine. Is this still an issue?
[2015-09-03 19:00:15]
It is an issue at the wrong a Account Name or Password is used.
It will not be an issue for Infinity customers.
We will have a new release out before the end of the day.
