Date/Time: Fri, 18 Sep 2026 01:57:51 +0000
Vertical Line times and dates have disappeared?
View Count: 1180
| [2015-09-02 13:56:20] |
| LadyTrader - Posts: 19 |
I did an update last night to version 1290 and when I logged on this morning, all of the vertical lines I have on my charts for the past days with times on the intra-day charts and dates on the daily, weekly, monthly charts have disappeared. If I add a new vertical line, it puts the time or date there. If I go back to a vertical line I used yesterday and try to add the date through the properties, it will not add it. By the way, the addition of being able to use vertical text is great - very appreciated. Thanks |
| [2015-09-02 18:33:28] |
We are checking on this.
