Date/Time: Sun, 22 Dec 2024 22:23:52 +0000
Package
View Count: 742
[2015-09-02 10:30:51] |
User184761 - Posts: 11 |
Looking to trade emini (YM). Whitch package do I need to pick?
[2015-09-02 10:53:27] |
Any service package will work, but the question is where will you get the futures data from? For the answer to this question, refer to this section here: https://www.sierrachart.com/index.php?page=doc/data.php#FuturesData Looks like you are going to use CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
