Date/Time: Sat, 23 Nov 2024 00:53:28 +0000
User Email Question - IB Trading
View Count: 1589
[2013-06-13 16:40:11] |
Sierra Chart - Max - Posts: 5730 |
I had linked my account to IB. When I enter a trade with a stop order and a stoplossorder attached, the stoporder goes to IB but the stoploss goes to IB after that the stoporder is filled. That gives a big problem, when for whatever reason the connection to IB is lost before that the order is filled. Is there a solution for that problem now? Sierra Chart Support |
[2013-06-14 05:28:03] |
We understand what you are requesting and currently this is not supported. It is in our longer-term plans to add support for this but it will not be anytime soon. What you can do is enter the order through Trader workstation in the case where you do not expect the main order to fill for a while. This is what we recommend doing. Otherwise, you can enter the order within Sierra Chart. Either way, you can manage the orders from within Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
