Date/Time: Sat, 01 Mar 2025 08:02:18 +0000
Apex Futures
View Count: 2028
[2015-09-01 16:59:22]
User549604 - Posts: 27
How do I get Sierra charts to work with Apex Futures as my broker. I'm using CME for the data service.
[2015-09-01 17:45:29]
Normally Apex Futures uses OEC. Therefore, follow the set up instructions here:
https://www.sierrachart.com/index.php?page=doc/openecry.php
Let us know if you need more help.
[2021-09-29 14:46:57]
User334419 - Posts: 17
Hi
I would like to know if it is possible to use apex to have several leeloo account to connect to sierra chart ?
Thnaks for your response
[2021-09-29 14:58:52]
John - SC Support - Posts: 38292
Not unless Apex is now using CQG or Rithmic for their order routing, as we are no longer supporting OEC.
If they are, then let us know which one and we will point you to the proper documentation.
