Date/Time: Sun, 22 Dec 2024 21:03:04 +0000
spreadsheet repeat the last values from the previous row
View Count: 848
[2015-09-01 08:46:09] |
User251871 - Posts: 16 |
Hi I use spreadsheet of SC two months ago (new spreadsheet) again noticed that a new row created before the bar at graph created And when this happens I have in the new row the last previous value instead zero? notice: when I do back replay testing I don't have this problem, only happens at real time data. is there any setting I need to set? |
[2015-09-01 09:15:18] |
We cannot help at all with this as it is presented. We have almost no information as to specifically what you are doing. The Chart Settings, the Study Settings, and the studies being used. Also your Sierra Chart account is expired. You need to renew. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-01 09:15:54
