Date/Time: Sun, 22 Dec 2024 20:48:55 +0000
SL disappearing CTS T4
View Count: 960
[2015-09-01 08:45:02]
User171335 - Posts: 1
I'm testing out SC on TST.
Something strange happened when I cancelled a TP:
I click the X on TP cancel on the chart and the SL also gets cancelled.
I've looked at the logs and there's no error/issue regarding this.
It's never happened on sim, I can't recall it happening on live before.
I sometimes use TP and sometimes I remove them.
I've looked at the logs, the only line that looks suspect is:
Order  2015-09-01 02:32:48.001  CL.20151000.CME_NY  CTS order update (Canceled). Info: OCO Pull  39917  6B60F2B7-E24F-49B5-A95C-61E85EB97950  Stop  1  Sell  47.54    Canceled
But I don't understand what's happening.
Edit: Video deleted, thanks for the info.
Date Time Of Last Edit: 2015-09-01 09:38:00
[2015-09-01 09:28:47]
We do not accept videos unless requested:
Support Board Posting Information: Do Not Post Videos Unless Requested!
The behavior you see is normal with CTS server-side OCO.
There are two things you can do.
Make sure the main/parent order is not a Market order but instead a Limit order. This will therefore use a full server side bracket order.
Or disable Global Settings >> General Trade Settings >>Use Server-Side OCO and Bracket Orders.
[2015-09-01 09:49:34]
Here is the relevant documentation for this problem you experienced:
https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#CTSServerSideOCOBracketBehavior
