Date/Time: Sun, 22 Dec 2024 20:51:14 +0000
just switched to CQG & am getting connect/disconnect messages from Sierra
View Count: 870
[2015-08-31 16:21:24] |
User11638 - Posts: 21 |
Hi I just switched from AMP/TTnet to CQG today and now I am getting continuous messages in the message log that an SSL connection is being established and then closed by the remote side. |
[2015-08-31 17:27:08] |
We are going to solve the problem with these messages later today.
