Date/Time: Sat, 13 Sep 2025 04:47:08 +0000
1288 version update, unknown log message, + feature request
View Count: 1035
[2015-08-31 13:23:27] |
User94199 - Posts: 13 |
Hello, After updating SC today, I noticed repeating message in Log " HTTPS connection to www.sierrachart.com:443 (26) | Connected. | 2015-08-31 15:08:12 HTTPS connection to www.sierrachart.com:443 (26) | Starting TLS 1.2 connection. | 2015-08-31 15:08:12 HTTPS connection to www.sierrachart.com:443 (26) | SSL connection established. | 2015-08-31 15:08:12 HTTPS connection to www.sierrachart.com:443 (26) | SSL connection closed by remote side. | 2015-08-31 15:08:18 HTTPS connection to www.sierrachart.com:443 (26) | SSL object has been freed. SSL state is now disconnected. | 2015-08-31 15:08:18 HTTPS connection to www.sierrachart.com:443 (26) | Shutdown and closed. | 2015-08-31 15:08:18 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-08-31 15:10:12 HTTPS connection to www.sierrachart.com:443 (27) | Connected. | 2015-08-31 15:10:12 HTTPS connection to www.sierrachart.com:443 (27) | Starting TLS 1.2 connection. | 2015-08-31 15:10:12 HTTPS connection to www.sierrachart.com:443 (27) | SSL connection established. | 2015-08-31 15:10:12 HTTPS connection to www.sierrachart.com:443 (27) | SSL connection closed by remote side. | 2015-08-31 15:10:17 HTTPS connection to www.sierrachart.com:443 (27) | SSL object has been freed. SSL state is now disconnected. | 2015-08-31 15:10:17 HTTPS connection to www.sierrachart.com:443 (27) | Shutdown and closed. | 2015-08-31 15:10:17 " Whole process repeats itself like every 2 minutes. What is this? + feature request Can you add option for "Volume by price study", "Maximum volume bar width" attribute, add "minimum width in bars", something like TPO study has. Currently width of volume profile can be set only to "% of window or period length", and if you are zooming in or out, or changing size of the window, it always changes how it looks. Thank you in advance |
[2015-08-31 17:35:17] |
After updating SC today, I noticed repeating message in Log We will see about the feature request. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-31 17:35:39
