Date/Time: Sun, 22 Dec 2024 21:03:04 +0000
Draw Volume Profile and the new Control Bar
View Count: 1036
[2015-08-31 13:21:18] |
jwick - Posts: 142 |
Prior to the new control bar, I was able to attach different Volume By Price configurations to different tool configs (by saving the VbP configurations as a study collection and then attaching that to a tool configuration) when using the Draw Volume Profile tool. However, with the new control bar, I am no longer able to modify any tool configuration when using the Draw Volume Profile tool. Not sure if this was an intended change and if not, can the previous behavior be brought back?
[2015-08-31 18:45:28] |
I am no longer able to modify any tool configuration when using the Draw Volume Profile tool. We do see the problem and this will be solved in the next release coming out later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-31 20:48:26] |
Awesome! Thanks
