Date/Time: Sun, 22 Dec 2024 20:15:02 +0000
What does it mean when I get no responce from Support for a Post.
View Count: 862
[2015-08-31 09:47:48] |
blknsxy - Posts: 29 |
Does it mean you are considering it? Have no answer? Waste of your time, what? Thanks |
[2015-08-31 09:52:53] |
It can mean any of these.
