Date/Time: Sun, 22 Dec 2024 20:28:40 +0000
Different VbP on DOM and Chart
View Count: 1125
[2015-08-31 07:35:49]
User34947 - Posts: 42
Hi
v. 1287, Rithmic Trading, product is FESX 0915-Eurex. On DOM and Chart VbP is set to From Session Start Time to End. At certain levels they do not correspond.
Thank you
imageprofile.png / V - Attached On 2015-08-31 07:34:57 UTC - Size: 41.66 KB - 364 views
[2015-08-31 08:34:32]
Refer to this section here for help with this:
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#VolumeProfileDifferences
[2015-08-31 08:59:45]
I have checked everything, tried Edit >> Delete All Data and Download from the menu, but problem remains.
I have been using the same set up for chart and DOM since a while, never had a problem until last week, I suspect after upgrading. I'll try to go back to an older release.
[2015-08-31 09:14:17]
We thought the problem was with the Session Times.
However, it could be version related. Update to the current version. You do not have the latest version. Here are instructions:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
There was a Volume by Price problem that arose recently that we fixed which can cause this issue. The version you are running may have been affected by it.
