Date/Time: Sun, 22 Dec 2024 19:31:18 +0000
New Control Bar
View Count: 853
[2015-08-31 05:24:51] |
motorola7 - Posts: 19 |
Ver.1289- Can the control bar float now?
[2015-08-31 05:34:36] |
Yes. And we do not recall any limitation involving floating of the Control Bars. That should have worked in the version that released the new Control Bars.
