Date/Time: Sun, 22 Dec 2024 20:49:25 +0000
Volume Profile not aligned to the far right side
View Count: 2171
[2015-08-31 01:57:49] |
User11527 - Posts: 10 |
Hello, Despite the fact that i have applied the following procedure: "When Volume Graph Period Type is set to Multiple Profiles Fixed by Time and you want to have the last displayed Volume Profile aligned to the far right side, then follow these instructions: Set the Right Align Volume Bars study Input setting to Yes. Refer to Volume by Price Input Settings for instructions. Set the Always Display Last Profile in View study Input setting to Yes. Refer to Volume by Price Input Settings for instructions. Set the Align to Far Right study Input setting to Yes. Refer to Volume by Price Input Settings for instructions." the last displayed volume profile is not disposed to the far right side |
Far_Right.jpg / V - Attached On 2015-08-31 01:53:42 UTC - Size: 535.34 KB - 512 views |
[2015-08-31 02:45:57] |
Actually, this is not necessary to set: Set the Align to Far Right study Input setting to Yes. But it will not cause a problem either. We cannot duplicate this problem. Provide your Chartbook with only a single chart which shows this problem. Here are instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-31 02:46:30
[2015-08-31 09:18:18] |
Hello, Joigned is the chartbook. Thanks |
Chartbook2.cht - Attached On 2015-08-31 09:17:37 UTC - Size: 152.96 KB - 331 views |
[2015-08-31 19:25:34] |
In your Chartbook you provided, this setting was set to No: Set the Always Display Last Profile in View study Input setting to Yes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-31 19:25:55
