Date/Time: Sun, 20 Sep 2026 09:54:56 +0000
Sync Chart Crosshairs across different Windows
View Count: 5479
| [2015-08-29 21:03:26] |
| whatasource2 - Posts: 7 |
Hi, On a previous version, you could hover over one bar on one window open and it would show the same location of the crosshair on the other window open. This is particularly convenient if you are looking at renko and time charts at the same time. I can't figure out how to get this to work though now and would like to be able to. Likely it is a setting or something. How do I enable this? Thanks. |
| [2015-08-30 06:04:21] |
Use the Global Cursor feature for this: Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
