Date/Time: Tue, 04 Nov 2025 19:21:24 +0000
Trailing Stop Attached Order
View Count: 1220
| [2015-08-28 05:12:46] |
| CustomIndicators - Posts: 126 |
I'm trying to get a bot to set a trailing stop connected to an order, but I'm not having the result I wanted. My bot had gotten into a trade, but didn't seem to set the trailing stop like I thought it would. Am I doing something wrong? How can I get an attached trailing stop to work? I couldn't find anything that would give me a better result. Here is a sample of my code that gets in, but not out. s_SCPositionData PositionData; int Result = sc.GetTradePosition(PositionData); int PositionStatus = PositionData.PositionQuantity; int chartNumber = 3; if (PositionStatus <= 0 && sc.GetStudyPersistentIntFromChart(chartNumber - 1, 1, 1) == 1 && sc.GetStudyPersistentIntFromChart(chartNumber, 1, 1)) { // Go Long int Amount = (PositionStatus * -1) + 1; s_SCNewOrder GoLong; GoLong.OrderQuantity = Amount; GoLong.OrderType = SCT_MARKET; int Result = sc.BuyEntry(GoLong); if (Result > 0) { s_SCNewOrder TrailingStop; TrailingStop.OrderQuantity = PositionStatus; TrailingStop.OrderType = SCT_ORDERTYPE_TRAILING_STOP; TrailingStop.Price1 = sc.BaseData[SC_LAST][sc.Index] - TrailingStopTicks.GetInt()*sc.TickSize; sc.SellExit(TrailingStop); } } |
| [2015-08-28 18:20:53] |
Is there a way to turn this into an attached order easily?
| [2015-08-28 19:08:37] |
Refer to this section here for help for this: Automated Trading From an Advanced Custom Study: Debugging/Troubleshooting Automated Trading Systems You cannot later attach a Target or Stop order to another order. That must be done all at the same time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-28 19:09:26
| [2015-08-28 23:29:10] |
That link shows me how to put the errors into the message log. Can you give me an example of how I can add in an attached trailing stop to my market order?
| [2015-08-29 00:17:01] |
As we said in our previous post, this cannot be done at a later time.
| [2015-08-29 02:47:27] |
I don't want it done at a later time. I want it done asap. How do I use attached orders? Or are attached orders in ACSIL impossible?
| [2015-08-29 03:37:23] |
Refer to the ACSIL Trading page and the structure members for s_SCNewOrder.
