Date/Time: Fri, 13 Nov 2026 08:57:49 +0000
Adding studies to exisiting spreadsheet
View Count: 1327
[2015-08-28 04:13:46]
User713273 - Posts: 409
Currently have a spreasheet alert and studies inputted, how do I add more studies to it?
[2015-08-28 10:32:26]
You just add them through Analysis >> Studies.
Make sure they are at the end of the Studies to Graph list in the Chart Studies window.
[2015-08-28 13:51:11]
Thx, is there also a quick way to add columns to existing spreadsheets?
[2015-08-28 18:17:34]
Do you mean additional formula columns after the default of 16 formula columns?
[2015-08-28 18:37:29]
yes, thx
[2015-08-28 19:05:17]
You need to increase the Number of Formula Columns input.
Depending upon the reference method you have to the study values in your formulas, you may need to update the formulas since the study values will be outputted to different columns after increasing this Input.
This is the reference method you should be using:
https://www.sierrachart.com/index.php?page=doc/doc_Spreadsheets.html#ReferencesStudySubgraphColumnsSpreadsheetStudy
Date Time Of Last Edit: 2015-08-28 19:05:42
