Date/Time: Sun, 22 Dec 2024 17:33:21 +0000
SC data feed
View Count: 786
[2015-08-27 14:27:45] |
binaryduke - Posts: 369 |
Hi SierraChart I'm currently enrolled in a TopStep combine using CME products. I also trade Eurex products through a CFD broker. I'd like to add Eurex charting into my SC installation. If I subscribe to the SC data service with Eurex support for real time Eurex data will I still continue to receive real time CME data through the TopStep CTS connection? Regards Lee. |
[2015-08-27 17:28:50] |
Yes this is correct: will I still continue to receive real time CME data through the TopStep CTS connection?
What you can do is install another copy of Sierra Chart: Using Multiple Data and Trading Services at the Same Time And set it to use the SC Exchange Data service after activating that service. Here are instructions for the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-27 17:29:49
