Date/Time: Fri, 04 Apr 2025 19:12:51 +0000
[User Discussion] - VbP Width + Length
View Count: 1838
[2013-06-13 11:50:14]
TastyRisk - Posts: 119
VbP:
I like a chart that shows the last few hours of price action using a range bar.
Therefore I use VbP with a Max width type "window width @ 95%".
The issue is when the previous session is in view...
At these times a Max width type "Period Length @ 95%" is much better.
It would be very good if there another setting like this: "Use period length but always fit in window".
I think that many users that like range bars would agree with ??
See picture if you need to understand what I'm looking at.
imageAB VBP 654654.png / V - Attached On 2013-06-13 11:50:10 UTC - Size: 127.82 KB - 596 views
[2013-06-13 11:59:21]
The end result should look the chart in this edited picture...
Also; days not in view (day before yesterday in my chart example) ; Might be drawn with a bar size of zero pixels as a side effect of this combination method (depending on how you code the VbP study / out of view objects) thus reducing memory usage.
imageAB VBP 654654 edited.png / V - Attached On 2013-06-13 11:59:18 UTC - Size: 35.7 KB - 601 views
