Date/Time: Sun, 22 Dec 2024 17:40:35 +0000
How can I get live/historical intraday data for DAX index (cash) ?
View Count: 3600
[2015-08-27 02:00:58] |
User837624 - Posts: 17 |
Hi, Could you recommend a source where I could get live DAX index data that would be compatible with Sierra? I'm currently getting GER30 from your feed and plan to use Infinity service later (I don't think they supply index/cash data though). I want to have the actual index data to compare with futures/CFD data. Any suggestions? Regards, Andy |
[2015-08-27 03:30:02] |
You can use TeleTrader for this: https://www.sierrachart.com/index.php?page=doc/TeleTrader.php They should have this data: http://technologies.teletrader.com/Financial-Services/TeleTrader-Data-Universe-%281%29/Cash-Markets---Indices.aspx Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-27 04:16:14] |
Thank you! Technically speaking, would I need to run 2 instances of Sierra: for TeleTrader and for SC Forex Data ? Regards, Andy |
[2015-08-27 10:14:42] |
Yes this would be the best way to avoid conflicts between them.
