Date/Time: Sat, 19 Sep 2026 23:55:52 +0000
Can SC be installed & operated from a usb drive instead of the hard disk?
View Count: 3003
[2015-08-25 20:27:55]
TraderTen - Posts: 80
I would like to use a removable drive to install my SC program on. Will it be alright if I do so from a usb or other solid state removable drive (SSD)? Could there be disadvantages in doing so?
As an alternate, having the data on a removable drive would satisfy my goal, while leaving the program on the main hard drive. Is that an acceptable variant for an installation of Sierra Chart?
[2015-08-26 05:50:11]
Yes, this will work as long as the drive is fast.
However, the computer must have the Microsoft redistributable package installed:
http://www.microsoft.com/en-us/download/details.aspx?id=8328
[2015-08-28 22:28:41]
Alright, I have bought a usb 3.0 64gb solid state drive. My understanding of the process would be as follows:
1) uninstall SC (after copying Data).
2) download redistributable
3) re-install SC (while selecting the external drive as location of Data File)
4) copy the data back-up onto the usb drive, where the Data file should be.
Would this be correct?
[2015-08-31 09:15:47]
The relevant instructions are in help topic 15 here:
Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html
To remove Sierra Chart from existing location follow the instructions here:
https://www.sierrachart.com/index.php?page=doc/download.php#Uninstalling
