Date/Time: Sun, 22 Dec 2024 17:31:18 +0000
Chart Values tool bar
View Count: 917
[2015-08-25 17:27:39] |
Ed Meckelborg - Posts: 71 |
Re Chart Values for Tools: I wish that the programmers would create another format for “Chart Values for Tools” . The current rectangular box format interferes with chart analysis. The old format had it on a tool bar. That was much better, especially for smaller screens. You wrote : This link works for us. What happens when you click on this link? What web browser are you using? https://www.sierrachart.com/downloads/1269SierraChartSetup.exe I’m using Internet Explorer. I down loaded several times getting the same result. I keep getting SH Historical Data. I would like the SC that allows using data from Interactive Brokers What is the latest SC “Interactive Brokers” version that uses the old tool bar that I’m looking for ? Thanks Ed |
[2015-08-25 18:01:47] |
Set your telephone number here: https://www.sierrachart.com/usercp.php?page=ManageAccountInfo Let us know when this is done and we will call you and use remote assistance to help you with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-25 18:01:58
[2015-08-25 20:23:51] |
done
[2015-08-26 05:54:23] |
We have made a revision to the latest prerelease. Update again with Help >> Download Prerelease. We corrected the problem with the Crosshair showing with the Pointer tool selected and some other minor changes. Refer to the attached image for the settings you need in Global Settings >> Tool Settings. Also enable the following: Tools >> Auto Snap on Creation Uncheck: Global Settings >> Tool Settings >> Include Open/Close in Auto Snap Adjust the Auto Snap Sensitivity as required. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-26 05:55:44
2015-08-26_175121.png / V - Attached On 2015-08-26 05:54:43 UTC - Size: 12.68 KB - 322 views |
