Date/Time: Sun, 22 Dec 2024 17:14:24 +0000
Gene Sheldon
View Count: 784
[2015-08-25 10:51:25] |
User72965 - Posts: 115 |
Can't change from 10 $ to 57.25 needed?????????? Hassle paying Sierra !!!!!! Been through this before!!!!!!! I would like to set up my Bill Pay (very easy) to pay. Need bank acc't # or an adrees to send to... I think can use e-mail address... Not sure about that? So not sending till can put in correct am't......... When opened Sierra <> window came up to pay.. Followed it > when to change 10 to 57.25 could not do it. Only send 10.00 ???????????? Thx Gene :) |
[2015-08-25 17:24:29] |
We see that you did successfully today make a payment for 57.25USD to the Additional Services Balance. Do you need further help with this?
