Date/Time: Mon, 23 Dec 2024 01:22:03 +0000
Squeeze alert
View Count: 850
[2015-08-24 21:54:09]
User699694 - Posts: 49
I have the bolinger squeeze on the chart.
When the squeeze is on I wanted the background of the chart to go a certain color.
I tried setting so that when the squeeze is on I selected the background option but nothing happened.
Suggestions?
Date Time Of Last Edit: 2015-08-24 23:00:26
[2015-08-25 18:07:50]
Refer to this page for instructions:
https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html
We cannot provide you a specific formula to use. You need to work that out.
You will want to use the Color Background Based on Alert Condition study:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s252
It will not color the entire chart background, only the background at the bar where the Simple Alert Condition formula is true.
Date Time Of Last Edit: 2015-08-25 18:08:28
[2015-09-07 17:23:09]
Hi is there a way I can see he actual day of the week on the time bar at the bottom as opposed to just the dates?
Thanks in advance
[2015-09-08 08:43:40]
You need to use this setting in Chart >> Chart Settings for this:
https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#DisplayDayofWeek
