Date/Time: Sun, 22 Dec 2024 17:22:04 +0000
Numbers Bar Calculations
View Count: 773
[2015-08-24 19:17:20] |
User787778 - Posts: 142 |
Hi Please add the POC value, for each bar, to the Numbers Bar Calculation study. You already calculate the volume, for each bar, at the POC. Thanks |
[2015-08-24 19:32:23] |
We will see about this.
[2015-08-26 00:49:24] |
Al SC Developer - Posts: 434 |
POC Value has been added in the next version.
