Date/Time: Sun, 22 Dec 2024 17:28:24 +0000
market depth to excel or spreadsheet
View Count: 2623
[2015-08-24 18:04:46] |
User307013 - Posts: 16 |
hi i appreciate this software since a long time is there a way to get the market depth levels in a spreadsheet or excel to make calculation? bests regards |
[2015-08-24 21:05:27] |
Yes. This can be done with the Depth of Market study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s156 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-26 14:23:45] |
ok i get sierra chart data feed and get only bid ask no depth (in ib i am in pro user ) hox can i get the depth with the sierra feed? bests regards |
[2015-08-26 14:42:48] |
ok i see i will try to deactivate cme and reactive the version with depth thanks for all |
[2015-08-26 17:23:39] |
Yes. This is documented here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#AddingCMEMarketDepth Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
