Date/Time: Mon, 28 Sep 2026 07:36:50 +0000
alerts
View Count: 1340
| [2015-08-24 17:01:25] |
| markuz - Posts: 90 |
I'm trying to setup an alert when the candle closes two ticks from the top wick and also when it closes two ticks from the bottom wick. I've used this formula h>=c+2 (top wick) h>=l+2 (also tried) that last one is H=L+2 It's not working. Do you have any suggestions? |
| [2015-08-24 17:53:36] |
Is this a Simple Alert formula? Also what is the tick size for the symbol of the chart?
| [2015-08-24 19:20:07] |
Simple Alert. bonds 1/32
| [2015-08-24 19:45:45] |
Use this formula: = OR(H-(TICKSIZE*2)=C, L+(TICKSIZE*2)=C) Modify it to meet your specific requirements. It should serve as a good start. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-08-24 19:51:05] |
Thanks!!
