Date/Time: Sun, 22 Dec 2024 15:36:56 +0000
SC1286 Pre release Window Tiling Issues
View Count: 785
[2015-08-23 22:04:43]
TechTrader - Posts: 116
Cannot retile windows correctly using the WTV/WTH toolbar buttons. Reverted to SC1282.
[2015-08-23 22:34:33]
Precisely what is the problem? This does not give us any useful information.
Date Time Of Last Edit: 2015-08-23 22:34:55
[2015-08-23 22:42:45]
One change that was made is that the order of tiling of the chart windows is going to be according to the order they are listed in Window >> Windows and Chartbooks.
So if you want to change the MDI window tiling order, change the order of the chart windows in Window >> Windows and Chartbooks.
There is no issue here. This functionality works better than it did before. It works better and we will not make any changes.
Date Time Of Last Edit: 2015-08-23 22:44:27
[2015-08-24 00:03:17]
I've always left clicked and highlighted windows in a chartbook in the order I wanted them tiled(from bottom to top or right to left). Left clicking the WTV/WTH buttons automatically then tiled the windows. This didn't work for me with prerelease 1286. Reverting back to 1282 gave me this function. I've tried your suggestion in post#3 with 1282 and that doesn't work.
[2015-08-24 00:19:57]
What is described in post #3 with Window >>Windows and Chartbooks only is going to work in the newer versions starting approximately at 1286.
