Date/Time: Sun, 22 Dec 2024 17:36:20 +0000
Tabs Partially Hidden
View Count: 924
[2015-08-22 10:24:37] |
User765038 - Posts: 22 |
SC Support, Chartbook and MDI tabs have become partially hidden (occurring after I changed the tab font size) as in the following image: http://www.sierrachart.com/image.php?l=1440238434498.png What adjustments should I make to expose the full tabs? Thanks and regards, Rod |
[2015-08-22 23:25:47] |
Restore the chart window that is visible and then maximize it using the standard controls for this at the top right of the chart window. If that does not work, then restart Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-22 23:27:36
[2015-08-23 08:52:42] |
I have restored and maximised all charts and restarted both Sierra Charts and Windows all with no effect. Note that the tabs appear to be hidden by the main (grey) window (not the tabbed chart windows) as in the following screen shot: http://www.sierrachart.com/image.php?l=1440319473333.png Any further advice appreciated. Thanks, R |
[2015-08-24 18:40:28] |
We need to research this problem. Please give us a couple of days.
