Date/Time: Sat, 04 Jan 2025 07:08:50 +0000
[User Discussion] - Estimated Position in Queue (EPIQ) on DOM
View Count: 2760
[2015-08-22 09:49:01] |
User60518 - Posts: 106 |
Hi - I use Sierra using CTS data feed - is there a setting on the DOM to show EPIQ for limit orders on the DOM?
[2015-08-22 23:15:42] |
No.
[2016-01-05 17:09:00] |
Paul.M - Posts: 113 |
This is in Ninja8 (as well as in all the PRO DOMs like XTRADER, ....) I vote 1x for getting this in Sierra's DOM :) |
[2016-05-27 16:33:54] |
just wnated to check if this is something you would consider in the future?
[2016-05-27 21:56:19] |
No, it is not anything coming soon. You will have to use another program for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-27 21:56:28
[2016-05-27 21:57:36] |
kinghat - Posts: 120 |
sounds like a good feature.
[2016-05-28 08:58:37] |
Cavalry3162 - Posts: 523 |
it really is and it could actually improve the sim trading as well. if SC would alter the filling mechanism accordingly.
Date Time Of Last Edit: 2016-05-28 08:59:40
[2016-05-29 18:45:45] |
norvik_ - Posts: 106 |
The key word of this feature describtion at XTRADER page is "approximately". Exact calculation of this value is impossible without L3(non-aggregated orderbook) data, which are avaliable only for licenced Market Makers in NASDAQ, and I don't know about CME is it possible to get it at all or not.
[2016-05-29 19:19:07] |
cme will provide full book from q3 this year.. see http://marketsmedia.com/cme-launch-market-by-order-level-3-data-solution/
[2016-05-29 19:44:23] |
Thank you, interesting news.
[2016-06-01 16:21:32] |
I have an answer from Rithmic, they planning impliment level 3 depth data transmission at the end of the year.
Date Time Of Last Edit: 2016-06-01 16:22:50
[2016-06-01 16:24:31] |
thanks norvik. so it shouldnt be any issue for barchart to do the same.. (hint)
