Date/Time: Sun, 22 Dec 2024 14:55:23 +0000
Quick to locate the specific time
View Count: 862
[2015-08-22 06:14:00]
User17064 - Posts: 70
Hi SC support,
Like MT4 platform, it has one small arrow under the chart interface which could quickly locate the date which I would like to see in LTF. For example, If I am interested in the date 2011.2.1. When I am in daily timeframe, I move the small arrow to that date and change the timeframe to H4, if even drill down, then just change timeframe to even lower like M5. It is quick
But in SC, only quick way is using "Go to date"function. Do I miss some easiest way in SC or no such function.
[2015-08-22 23:30:17]
Yes, there is only the Chart >> Goto Date-Time command and you can add a Control Bar button for that.
Date Time Of Last Edit: 2015-08-22 23:30:31
[2015-08-23 01:10:37]
Will SC consider to add that function in the future? It is much more easier than Go to Date-Time function.Thank you!
