DTC Protocol Discussion Forum
- DTC Protocol Discussion Forum |
- Search Board |
- Control Panel |
- View My Posts / Threads |
- Direct Messages
Date/Time: Tue, 04 Nov 2025 15:43:06 +0000
64-bit Integer for Orders
View Count: 3261
| [2015-08-20 09:39:37] |
For the integer order messages, the data types are being changed from 32-bit integers to 64-bit integers. This will be in DTC version 7. 64-bit market data messages will also later be added. Date Time Of Last Edit: 2015-08-20 09:40:04
| [2015-08-25 17:14:03] |
| vbmithr - Posts: 204 |
The field quantity should also be an int. It represent an exact quantity that would be better represented as an int rather than an imprecise double.
| [2015-08-26 08:42:27] |
The Position related messages should also have int64 variants. Actually, absolutely all messages that use a double to represent a price or a quantity should have a int64 variant. |
| [2015-08-26 19:15:16] |
This is going to be changed in the next release.
| [2015-08-30 20:47:15] |
Ok. For now I'm not going to use int messages (since apparently you internally convert them to doubles in SC anyway). I will use them only when DTC will be consistent regarding int messages (i.e. all messages that use floats for non-real numbers). |
| [2015-09-01 01:15:56] |
OK this is fine. We still have not yet implemented full 64-bit integer support for market data and trading.
