Date/Time: Sun, 22 Dec 2024 14:02:07 +0000
Roll up more on DOM
View Count: 777
[2015-08-20 08:49:10] |
idcisosf - Posts: 34 |
I want to roll up the Dom, but it stop at same point, and can't go further. So, how can I roll up more for I need to put an order at more roll up prices. Thanks. |
[2015-08-20 11:23:34] |
This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ScalingTheChartDOM.html You will need to use Interactive Scale Range to increase the range of displayed prices. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
