Date/Time: Sat, 23 Nov 2024 03:55:54 +0000
Difference Chart Question - What causes this?
View Count: 1696
[2013-06-12 20:48:21] |
infpz - Posts: 826 |
It looks normal the majority of the time, but every here and there, we get strange spike which mathematically does not make much sense.
difference.png / V - Attached On 2013-06-12 20:48:08 UTC - Size: 31.71 KB - 556 views |
[2013-06-12 22:23:06] |
We will need to get the Chartbook to test this. It can be provided by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-13 11:10:46] |
Attached. Scroll back a little and let me know if you see the same thing. Thank you
Difference Charts - Sample.cht - Attached On 2013-06-13 11:10:26 UTC - Size: 102.67 KB - 748 views |
[2013-06-14 17:27:54] |
Just checking on this. Thank you.
[2013-06-14 18:04:10] |
In the Study/Price Overlay studies, set the Fill Blanks With Last Value inputs to Yes. This will solve it.
