Date/Time: Sun, 22 Dec 2024 13:57:23 +0000
Alert Manager
View Count: 1041
[2015-08-19 19:39:08] |
User22591 - Posts: 133 |
I noticed I lost the alert mgr. information when I turn off the computer. 1 Can the information be saved or transpose? 2 Can individual line items be saved? 3 How can I retained any of the information from the log? Winston 770=-645-9998 |
[2015-08-19 20:41:32] |
Saving the lines in the Alert Manager >> Alerts Log is not supported. If you select the lines in the Alerts Log of the Alerts Manager, you can select Edit >> Copy Selection to copy them to the clipboard and then you can save them in a text file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
