Date/Time: Tue, 29 Sep 2026 12:35:16 +0000
No Sound on Spreadsheet Alerts
View Count: 2072
[2015-08-19 15:43:55]
Maharishi1 - Posts: 4
Can you think of any reason why I am not getting sounds when I get signals from my spreadsheet system? I've had sounds with other systems in the past and just can't wok out why I'm not getting them now.
[2015-08-19 19:08:44]
Refer to this troubleshooting section here about this:
General Settings Window: Troubleshooting for Alert Sounds That Do Not Play
Date Time Of Last Edit: 2015-08-19 19:10:09
[2015-08-19 19:42:20]
Thanks, but it didn't help. There are no alerts showing in the alert manager, but the spreadsheet is putting signals on my charts.
[2015-08-19 19:48:47]
Sawtooth - Posts: 4355
Here are some tips on spreadsheet alerts:
"Understanding Alerts within spreadsheet studies"
http://www.sawtoothtrade.com/tip-6.html
[2015-08-19 20:30:49]
Are you using the Spreadsheet System/Alert study?
[2015-08-20 13:19:23]
Yes
[2015-08-20 17:04:15]
Replay the chart. Set cell K3 to FALSE, then set it to TRUE. Do you then get an alert message in the Window >> Alerts Manager >> Alerts Log?
[2015-08-20 18:22:57]
No, nothing.
[2015-08-21 09:35:05]
This is not making sense. Are you sure you are using the Spreadsheet System/Alert study?
Here is a test procedure which has been developed for the Spreadsheet System for Trading study:
Spreadsheet System for Trading Test Procedure
We recommend going through it to give you an example of performing a test. It does apply to the other Spreadsheet study, but the general logic for Alerts remains the same.
Actually, refer to the documentation here about this:
https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#IgnoredSignals
What is the Draw Style for the column K Subgraph set to? It needs to be something other than Ignore.
Date Time Of Last Edit: 2015-08-21 09:36:40
