Date/Time: Sun, 22 Dec 2024 14:06:35 +0000
Vertical Panning
View Count: 1091
[2015-08-19 15:37:16] |
User147890 - Posts: 3 |
I can use the hand feature to pan left and right, but I am unable to pan vertically. Is there a setting I need to change somewhere? THe "hand" does have a 4 way arrow on it so I assume it can be done?
[2015-08-19 18:55:27] |
This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#Hand Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
