Date/Time: Sun, 22 Dec 2024 14:05:27 +0000
Recent Bid & Ask Volume - Chart DOM
View Count: 825
[2015-08-19 13:04:01] |
User78442 - Posts: 260 |
What are the parameters to define recent and are these parameters changeable anywhere? Thanks
[2015-08-19 17:09:22] |
This cannot be changed. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#ChartDOMColumnDescriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
