Date/Time: Sun, 22 Dec 2024 14:32:22 +0000
TICK_data
View Count: 765
[2015-08-19 09:51:45] |
User45317 - Posts: 18 |
Hi, I use SC exchange data feed and I have connect interactive brokers account. Ho much history is data tick by tickt. THX
[2015-08-19 10:33:26] |
This depends upon the particular exchange. For futures there is at least 3 to 4 years of historical tick data. For stocks it is at least 6 months. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
